costa_rican13 »
https://forums.nicoclub.com/costa-rican13-u102599.html
Tue Jun 08, 2010 9:08 am
i picked up some i30 dual fans from a local junkyard. and well i've discovered these fans have a low and high level. well there's 4 wires for 2 sets of wires for each level on each fan hence the two levels of power. so all in all there are 8 wires. 1 high, 1 low for each fan. now my questions are which levels should i use? and how can i wire these to where i wont have to use a toggle switch? As of right now i have a wire tapping the power to the radio, so when i turn the ignition on, the fan comes on too. but im afraid this wont be able to power the 2 fans and radio.. im aware of ppl wiring to the water temp sensor or the a/c unit. but i do not have a/c in my car. is it still possible to wire it to the a/c? im not sure.. what about the water temp sensor? also i cannot afford to buy a fan controller, this is why im asking you guys about an easy simple way to wire these fans up. any help is appreciated alot. ive searched also and seems nobody has the i30 fans or didnt do a write up about them.
