I30 Bose replacement
Post all your Nissan electronics, car audio and stereo questions here!
Mayhem_J30
Car: Ummm...My Car
Can I assume that the I30 Bose setup is much like the J30? As in the head unit can be replaced with an aftermarket with the correct adjusments (the originally speakers will remain).
The GF's I30 cd player is dead and we don't feel like spending $200+ to have it fixed. I would rather just put in a new unit that looks sharp and can at least match the stock Bose unit quality. We're not stereo maniacs so as long as it works we'll (she'll) be happy. But I don't want the distorted sound that people have complained about when switching to an aftermarket unit. The I30 has the 6 speaker setup.
We will be taking the I30 to a local shop that has a lot of experience working with Bose, but I still want to be able to walk in there and tell them what NEEDS to be done and how I want it done.
Also, is it possible to get a decent head unit in the $200-300 range? I haven't researched car audio stuff since I was in high school (8 years ago) so I'm a bit behind.
scruf1986
Car: the car
The head unit there is tons of stuff. A Pioneer Premier 650 cost about 270 and is very much top of the line. The only thing that head unit is missing is the 4 volts. It has 2.2 volts which in my opinion is actually better. And its missing some cell phone mute thing that the Pioneer 9400 has. So I would go with the Premier 650 or the Pioneer 6500. They are both below 300.
Mayhem_J30
Car: Ummm...My Car
scruf1986 wrote:The head unit there is tons of stuff. A Pioneer Premier 650 cost about 270 and is very much top of the line. The only thing that head unit is missing is the 4 volts. It has 2.2 volts which in my opinion is actually better. And its missing some cell phone mute thing that the Pioneer 9400 has. So I would go with the Premier 650 or the Pioneer 6500. They are both below 300.
Thanks scruf, that at least puts me in the ball park for the unit.
Eswift
Car: should be obvious enough
for that case, chris, you will want something like this line out converter.
http://store.yahoo.com/logjam/piehrcniss.html
i didint have a chance to go to the PIE website, but it looks like you may be able to keep the bose amps in there as well
Eswift
for future reference,
something like this
http://www.logjamelectronics.com/sounlocbosli.html
can be used to get outputs from the OEM bose to be sent to an external amplifier for subwoofers or what have you.
Mayhem_J30
Car: Ummm...My Car
Eswift wrote:for that case, chris, you will want something like this line out converter.
Wow, that seems almost too convient for the conversion. The application years stop at 94 and the I30 is a 96 although 94 falls in the same generation gap for that model. If it's that simple I could do it myself (and replace those a/c bulbs to while I'm at it)
Eswift
hehe, this ones for 95+
http://store.yahoo.com/logjam/piehrcniss95.html
i would call them to make sure it will work...
Mayhem_J30
Car: Ummm...My Car
You think this will work too?http://www.installer.com/cars/nissan.html Part #NISAH4N
What about the antenna? There's got to be a switch that sends power to the antenna so it'll extend when the radio is on. Is this typically compatible?
Simmsled
Car: TSI GTI - E46 325i
Hey chris... get the NISAH4 and the Metra antenna adaptor model # 40-NI10. this will be best.
