oh ok...got it.. (exhaust confirm) yah, you're good there
HFC's definately!! you can pick those up pretty cheap -- just search the classifieds within G35 Forums.. I got mine used and it was worth it to me instead of paying close to $500 Brand new....
you can find used HFC's under $300...you can also pick up an HR style ypipe (used from a G35 Rev up) or the Motordyne xyz pipe...then a Megan mid pipe...connect to your existing mufflers...
But for right now and staying within a good budget: the z-tube, drop in and Uprev will be good...(may consider the 5/16 plenum spacer)...you will have good gains...then when you're ready, add the exhaust mods listed above -- keep in mind, you will need to re-tune if you add more mods after your initial tune.
...not to sure about the Uprev data logger...I went with the Uprev done at a pro-tuner = $500 for Uprev to be added, 3 dyno runs (got an additional), 5 maps to select (drive by wire), cam timing increase, A/F ratio improvement, rev limiter increase...
I'll search my prior posts regarding my dyno numbers related to the mods I added...and at different times...
you're ride looks really clean
I noticed in picture 2, there is another M in the background (left side)....is he on the NICO forum also???
