sewan park wrote:...
... How I can upload photo???
The easiest way I've found: I use tinypic.com. Its super quick and requires no membership, no application, no user id, and no registration!
Simply navigate to tinypic.comClick on Browse Navigate to the picture stored on your computer Click on - Upload Now (You can leave the Tags window field blank if you want)
(After you have clicked Upload Now... the window below will appear)Copy the row of data in the field labeled - "IMG Code for Forums & Message Boards"Paste the data you just copied... into your forum post.
The photo(s) will appear in your forum post after you finished writting your comments and clicked on the save button.Note: If you have more than one photo you want to share, you will need to upload them to tinypic, one at a time, and copy the IMG Code data into your forum post for each upload.
Modified by Elton Noway at 11:39 AM 1/31/2010
