•Remove the plastic parts from the vehicle, if possible. This allows for more thorough cleaning and preparation. If you cannot remove the part, mask the area around the it.
•2
Wash the plastic auto part with car wash soap and rinse with water. Allow it to dry completely, then wipe the plastic with rubbing alcohol. Use a lint-free towel to wipe the part with wax and grease remover.
•3
Sand the plastic auto part with 800-grit sand paper and water. Keep the paper soaking wet while sanding to keep dust from building up under the paper and scratching the part. Rinse the part and allow it to dry.
•4
Apply an adhesion promoter to the plastic part so that the primer and paint will stick to it. Apply the adhesion promoter just as you would paint--with light, even coats. Allow it to dry. Prime the part with two thin coats of primer, allowing each coat to dry.
•5
Paint the plastic auto part with three coats of paint. Allow each coat to dry completely. Spray two coats of clear on the part and allow it to dry overnight.
Read more: How to Paint Plastic Auto Parts | eHow.com http://www.ehow.com/how_4964075_paint-p ... z111obSovC
