proxim2020 wrote: Anywho, I do agree that the problem isn't the back brakes alone. It is with the design of the car itself rather than the brake... Stiffening the front end or adding weight to the back could prevent the nose dive, which would help the back stay down. Adding disc to back really won't give you a benefit if you can get the back wheels to pressed firmly against the ground when stopping hard.
I agree with you 100% on this. The brake dive is really excessive, and I would be interested to see instrumented braking tests before and after someone installs stiffer suspension. And I can't ignore the tires. They are the limiting factor in braking traction.
I was thinking that if someone wanted to race their V competitively, this might be an option to improve braking performance (assuming that this person has already upgraded suspension and tires).
