s14=pimpin' wrote:Hey, if you have any good pointers, please pass the knowledge!
Ok, here's a pointer, sell the S14, get a bad-boy S13 and don't put so many damn pictures in your sig.
In a heel/toe downshift, you don't necessarily have to use your heel and toe. You are on the brake, clutch in, and tap the throttle with the right side of your foot while it is still on the brake and clutch out just as the rpm comes up for a smooth transition in gears that does not upset the balance of the car in the turn, thus allowing you to maintain superior control and lap the sh.it out of s14 newbie, non-shifting, slow a.ss.
In turns that are wider that you don't need to brake for, you can clutch in, shift and tap the gas with your toe just as you clutch out and then brake if you need to.
Anything else Paulie?
