So ive got a BIG issue with the CA/240....
im trying to get it running for the future owner, whoever it may be. And i thought i had the issue pinpointed as being the ignitor. But i was very apparently wrong.
I have faint spark on Cyl 1 and NONE on cyl 2 3 or 4. the injectors pulse so i know the cas is working. i checked all the coilpacks via the FSM instructions. The emanage shows Green light and Yellow light which is supposedly normal, and the ECU has both red and green lights on which i also believe to be normal.
Its been so long since ive pulled codes off the ecu in one of these that i forgot how to count the flashes but it goes 1 long 2 short 3 short 4 short 5 short whatever that means.
when we first plugged in the emanage, i spaced out like the pollak i am, and forgot to unhook the ignition harness to load the firmware and there was a loud POP and an electrical burning smell under the hood area coming from the right side. Unfortunately, since i was in the car turning the key, i couldnt get out in time to see where exactly it came from
My only remaining thought is that it could possibly be a relay that controls spark or ignition but im not sure which one that is since i really dont ever pay attention to chassis wiring and fusebox. The fuses however looked fine to me.
Any help is appreciated...
my email is
[email protected] phone is 7725010582 (dont call after 9:30pm if you do)my aim is xFBCxNYHCx
you can reach me at any time on any of these
thanks guys!
