rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Wed Apr 02, 2008 12:20 pm
If you must go that route, all of your piping is not going to be easy or cheap. Your down pipes are going to be expensive to have made. Check out spearco intercoolers. Popular brand i guess..... I really don't see it being cheaper, i don't think you know the trouble your going to run into to have an end result of less horse power (possibly). Also, the turbo that comes on the turbonetics kit is good for at least 500 HP, but that doesn't mean thats what your going to get out of it. Your going to want at least 440cc injectors which aren't going to be cheap either. Also, you'll definitely want an ECU that can handle all of this, which recommened would be the UTEC by TurboXS. That + boost controller, is going to cost you around $1500. And to have it all tuned in (if you don't have a dyno), is going to cost you at least $500, at least. Thats $2000 for ECU, Boost controller, and dyno tune alone. Those are the most crucial items in building the most power out of your turbo kit..... Not to mention what the pipes you'll have to have made are going to cost you, then the intercooler, injectors, fuel pump, oil feed, waste gate, blow off valve.....Good luck my friend, good luck. My friend's dad put a custom turbo kit on his integra LS and it took months to get it right. He hired a guy (the best guy for honda's in columbus) to come finish it and it still took months. There is so many things you run into with premade kits, it just gets worse with custom ones. Thats why i'm having my premade kit installed professionally. Less head ache for me, and less down time. Plus it will be there for the tune as well. Let me know what you decide, if you go with custom, do a thread with pics and info, so people can refer to it that want to do the same thing. Good Luck...
