I Want To Try This
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
RioD007
zer...iping
What do you guys think?
I think it would definitely make it have an amazing intake sound...
gloa2000
Car: 04 Maxima SL, 08 EX35 LuxNav
This mod works well and actually it gives stronger sound than CAI set up and way cost less, you will not experience significant upgrade in power but sure it helps your MPG as well... and way easier to install than CAI.
AWGD8
Car: 2008 EX35 AWD JOURNEY
You`ll lose few hp due to heat coming from the engine. I don`t think it`s
worth it. I would rather get a fram filter for $11 and change it every 3
months. OUR engine has a unique 2 intakes and are more than enough to
grab cool air when the piston is at BDC. This is an NA engine and you are
at the mercy of atmosphric pressure and piston stroke. You gain more
heat = less suction difference. Save you`re money and soon we will have
more performance support for the EX35
You might probably decrease you MPG bec. you`ll be running lean and the
computer might adjust to give it more fuel just to keep it safe.
JCL622
Car: EX35
AWGD8 wrote:You`ll lose few hp due to heat coming from the engine. I don`t think it`s
yeap he got it right, it will sound GOOD, but you will get heat soaked alot quicker
nix this mod
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
