i want to replace my headlight covers
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
dtrento
i have an 2004 G35 sedan, my headlights are foggy and i want to replace them to be clear. I do not want to spend 300$ for the assembly, where can i find a inexpensive clear cover/lends? please help. thank you
frapjap
'07 Subaru Legacy
Welcome to NICO!
In most newer cars, you're stuck buying the whole damned assembly. Your best bet is to have someone clear them up, or try it yourself. Check out a couple of youtube videos, or take the easy way out and get a clean towel and some toothpaste and rub them out. It'll only last a couple of months at a time, but isn't nearly as expensive.
Better yet, do it like a pro. I've used this kit on several cars, and the results are awesome (IF you take your time and do it right).
This one is my favorite: Sylvania Headlight Restoration Kit. Consumer Reports confirms that it's a good one. :)
http://www.consumerreports.org/cro/head ... -guide.htm
Gary01
Car: 2008 Infiniti EX35
Hello, I just read your post about headlight restoration kits. My 2008 ex35 passenger side headlight is all faded and foggy. My driver side was replaced, so the right side looks even worse now. I do not want to replace the entire unit, way too expensive, plus it still works fine. I've read and looked at the kits, Sylvania, 3M, Meguiar kits are all the better rated ones. You said you liked the Sylvania the best. Can you tell me why and do you or anybody else know if it can permanently damage the lens cover. Any input/suggestions would be greatly appreciated. Thank you
Return to “G35 and G37 Interior, Exterior and Audio”
