I want to change me winkers to the corner lights and bondo out the og winkers
LuiGs14
Car: S14 1995 Nissan 240sx SE
I have a s14...I want to change me winkers/blinkers to the corner lights and bondo out the og winkers and just use the corner as blinkers and parking lights.I know i cant just replace wiring beacuse then the corners will only light up when signaling and i need them to light up as parking light and stronger wen they blink ...any suggestions???
theother1wstolen
Car: 92 240sx Coupe SE
if your talking about bondo-ing out the front blinkers like i think you area) that would most likely be illegal and you would probably get a ticket within the first weekb) bondo wont work on the flexible plastic bumper cover (not well at least)
h.240
Car: 1991 240sx hatchback
Could you simply add a second bulb to the corner light for the turn signal? Or reposition the turn signal bulb to the corner light? You may need to reposition the factory bulb in the housing, but I think it would work. Just make sure the bulb for the turn signal is brighter than the parking light bulb.
