I WANT TO BUY ER34GTT RB25DET NEO VALVE SPRINGS
DriftsideRacing.com
Car: er34gtt and ae86
Hi,
am having much trouble finding springs for this engine head.
Does anyone know where they may be available??
Specs are as follows:
rb25-287497A engine number
Spring Diamention is 25mm diameter ( outta diameter )
Inside Spring diameter is 18mm
Total Spring lengh 54mm long ( Inlet )
Total Spring lengh ( exhaust ) 49mm
Install hight 49.5mm intake
exhaust 44.5mm
currently about 48pounds standard.... But need 60pounds... Springs
Thanks,
Dayne
Carl H
tomei.
DriftsideRacing.com
No i foned tomei jp and they don't have any.
Seems er34 has 3 different head's and R33 ones are much shorter in Lengh etc
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
might be able to get you an upgraded set.
Will need to wait till Tuesday when everyone is open, to check.
DriftsideRacing.com
Hi Coolwhip,
have found some thank g__. Mallory had the correct size
Dayne
