AZ89two4Tsx wrote:They're both HP Media Centers m7657c. Idk how old they are, prolly a few years or so, my dad got them from work.
They're XP with "vista compatible" so they're not TOO terribly old.
They have a TON of usb ports and jacks for misc wires all over the front of the case. It's nice.
The "Vista compatible" sticker doesn't mean much. Microsoft seriously underestimated the minimum requirements for Vista.
The main issue is wattage. Any gaming-capable machine is going to need a 500w+ power supply at the very least. If your current parts machines only have 250 or 300 watt power supplies (common in non-gaming brand-name desktops) you'll have to upgrade. But power supplies aren't pricey. You can get a 650 watt power supply for ~$50-$100, or go with 500 watts and save even more.Newegg actually has a power supply calculator you can plug your parts into.
http://educations.newegg.com/t....html
If you're planning to run multiple hard drives (ideal, especially if you have them already available...install your OS to one and programs to the other) you will not want to go below 600watts with any gaming-capable videocard.
Oh, another thing to consider with videocards is DirectX version support. GTX 260 and Radeon 4870 both support DX10. Nothing from Nvidia supports DX11 yet, but ATI's 5000-series cards do. So if you go with one of those (~$120 for a 5750, which is a good midrange choice) you won't have to upgrade in two or three years when DX11 becomes the standard.
