I Want To Add 2 Solobaric 12s To My Stock Navi/Bose System
Rellz CT
now i've read through the FAQ
"Is it possible to add a subwoofer to the stock stereo?
Yes. With the Bose system, you will need to tap into the speaker wires in the trunk (it is best to do this before the amplifier). You should then use a line level converter to take the speaker wire signal and convert it to patch cables. These can then be plugged into the aftermarket amplifier. You will also need to connect a remote turn on lead (the signal that tells the amp to turn on so it is only running when the stereo is on). This can be easily tapped from the turn on lead that already runs to the Bose amp."
but im not sure if the stock amp can power those 2 subs
(4-ohm Solo-Baric L7)
up above seems like its explaining how to just add on a single sub
i want to hook up two....and these seem quite powerful
what should i do in this situation?
i really dont want to effect the quality of the original bose system because it sounds good to me already
i just want some extra bump in the trunk
thanks in advance
AppleBonker
Rellz CT wrote:now i've read through the FAQ
thanks in advance
I guess part of that FAQ is not the clearest. The tapping into the speaker wires is for the signal only (not to actually drive the speaker - think the RCA cables that connect your DVD/VHS to your TV). It still needs to be amplified. There is no way to power ANY aftermarket subwoofer with the stock Bose amplifier. You will still need to purchase an amplifier for the sub(s). In this case, the connection from the speaker wire in the trunk to the amplifier will remain the same. The only difference will be the connection from the amplifier to the speakers. And yes, this can be done without disrupting anything about the stock Bose system.
Rellz CT
thanks a lot man
so no sound processor is needed to tune my subs correctly??
or will they be ok just with just the amp
sorry if thats a stupid question..i really dont know much about this
and
now for my next question
what amp should i purchase for these two subs?
Modified by Rellz CT at 2:36 PM 9/2/2008
AppleBonker
If you are going to only add a substage, a sound processor will not be too useful. It wouldn't hurt anything, but you wouldn't gain enough for it to be worth purchasing in my opinion. If you were going to add a new amp and replace interior speakers, I would say it would be much more useful.
For the amp question, there are nearly an infinite number of options. For starters, we shall need to know approximately what budget you are looking at. That will narrow the search down considerably.
Rellz CT
I'm not trying to go over 500
I want a powerful clean sound
Rellz CT
whats the difference between these two L7 series
08S12L74
and
06S12L74
only difference i see is the 50 dollar difference and the design
any difference in performance?
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Rellz CT wrote:whats the difference between these two L7 series
08S12L74
and
06S12L74
the first two numbers represent what year the product began.... the 08= 2008S= Solobaric12= 12" wooferL7= series of the woofer4= 4 ohms (dual)
Rellz CT
oh I see
Still need those amp suggestions tho
Also
Will I need a compacitor?
AppleBonker
Rellz CT wrote:oh I see
Also
You've got $500 to spend on an amp? Man, it seems like all I do is push similar products to what is in my car:
Check this out
I've got the big brother to that amp (3000 watts rather than 1500), and I can't give it enough praise. Also, that price is a steal. Surprised it's on sale. On top of all that, the link above is to an authorized retailer, so it'll come with a full factory warranty! You can't go wrong with that amp!
Rellz CT
thanks a lot
Do u think I'll need a compacitor?
AppleBonker
Rellz CT wrote:thanks a lot
Whoops, completely forgot about that part of the question. I wouldn't add one. In my opinion, capacitors are largely worthless. I've used them before with minimal gain, so I'd save your money and leave the cap out.
Rellz CT
I appreciate your help
Thanks again
Rellz CT
oneeee more question
should i go with
2 ohms subs
or
4 ohms subs
what is the difference?
will i need a different amp from the one u suggested if i go with 2 ohms?
AppleBonker
Rellz CT wrote:oneeee more question
should i go with
2 ohms subs
or
4 ohms subs
Ah yes, I also forgot to throw this info out there for you as well. That amp can push 1500 watts RMS at a one ohm load (this would be 750 watts per sub which is the max they can handle). In order to do this, you'll need to wire to a one ohm load. The rest is purely physics. Go wit the dual 4 ohm voicecoil subs. Each sub will then have both VCs wired in parallel, giving an impedance of 2 ohms. Then, wire both subs in parallel to the amp, this will give an impedance of 1 ohm that the amp sees. Check the gain setting tutorial in the FAQ to set your gains and you're done! I can safely say that the sundown amp I recommended will be stable at one ohm, so this can be done safely.
Other than the impedance differences on the voicecoils, there are no differences between the two subs (so no benefits to one over the other except for wiring options).
rjdmmfl1
capacitors are largely useles, but in my case, they look cool!
seriously though, it may be worth it to put in something like an extra dry cell battery... (Kinetik 1400 maybe) that would be better than a capacitor!
AppleBonker
rjdmmfl1 wrote:seriously though, it may be worth it to put in something like an extra dry cell battery... (Kinetik 1400 maybe) that would be better than a capacitor!
That would definitely be better than a cap, but I doubt it'll be necessary in the OP's case (I don't think 1500 watts would require an additional battery - I've run that before on just a stock battery). Rellz, if you notice electrical issues (lights dimming with bass hits, etc), maybe think about improving the under-hood battery.
Rellz CT
man u guys are the TRUTH
thanks for all the help guys
AppleBonker
Rellz CT wrote:man u guys are the TRUTH
We help where we can. Glad you're finding it useful. Also, if you're going to look at that Sundown amp, I'd highly recommend running 0/1 AWG power and ground. 4 AWG would be cutting it close for that bad boy. I ran 0/1 in my car and it certainly isn't that much more difficult than running a smaller gauge.
