I want to add 2 sets of hids, But
TREYDEE007
Car: M35
I would like to add a set of 3000k hids for my fogs and a set for the high beam lights, but I want to be able to turn on the fogs whenever I want to.Should I jus run the fogs to an independant switch???
Thanks in advance
peterr22
Car: 2000 I30T
Im not gonna be much help.. but..On my I30 the previous owner wired the fog lights to come on with the parking lights not just the headlights. he did something with moving a wire in one of the fuse panels under the hood
as far as hid high beams go...i personally wouldn't because..Hid's have to "startup" and if you need to flash your lights at someone or even need to turn them on for a second they aren't as fast as regular bulbs.
xxNite
Car: 2004 Infiniti M45
'98 Toyota Supra Turbo
KP Technologies makes the following:Fog Light Controller Module Product Description: This module interfaces directly with the Nissan/Infiniti cluster matrix to enable completely independent control of the fog light system, while still using the OEM fog light switch.
see more info here:
http://www.kptechnologies.com/...ersal
TREYDEE007
Car: M35
xxNite wrote:KP Technologies makes the following:Fog Light Controller Module Product Description: This module interfaces directly with the Nissan/Infiniti cluster matrix to enable completely independent control of the fog light system, while still using the OEM fog light switch.
see more info here:
Thank you that was very helpful
