mersidoe wrote:But now my stereo's gone - it won't power up at all. I suspect a loose connection, but I'm not sure where to start the troubleshooting. I thought I read some threads about bad connections on the Bose stereos, but now I can't find them.
Any hints?
Mersidoe, the saying goes, never say never but the wiring harnesses that plug into the back of your stereo (assuming it's the stock unit) are designed to lock in place so they don't vibrate loose, etc.
However, anything is possible. To get to the harnesses, you'll have to pull out the head unit.
See this website for detailed instructions on how to remove the head unit.
http://carstereohelp.com/stere...o.htm
If the harnesses are good, check fuses, if those are good, then the head unit may be dead.
The folks at the above link specialize in repairing Bose head units. They repaired my head unit and it's as good as new. My unit however had a different problem than yours. My CD player quit working.
Good luck.
