I want my parking lights to flash w/lock unlocking of doors. Program issues!!???
Romo77
my car used to some time ago have the parking lights (corner lights) flash with locking of the doors. but it hasn't for a while. I'd like to fix it if possible. Should I re-program the remote kee or what?
thanks
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Mine do flash on the Q45. On the I30, if I hold the lock and unlock buttons, I can swap between the lights flashing, and the horn honking and he lights flashing. It is the same on the I35, because I do it with my loaner cars.
Does it lock and unlock the doors? When my Left Rear door LCI module failed, the remote stopped locking and unlocking the doors. I got one from a parts car, and all is well.
Have you changed the battery in the remote? This could have an impact, maybe.
Romo77
Thanks for your response.A few months ago the left rear door lock and window stopped working. But all others work, and I can lock/unlock. I just want my lights to flash when I do.I did change the remote battery some time ago. What effect would this have?
thanks
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Get a new module for the left rear door. That should fix it. Mine would not lock or unlock the left rear door with the remote or the interior switch. The window would not roll up or down from the console. What was cool, was the window would roll up and down fron the door switch, even if the key wasn't in the ignition!
Romo77
how much is the module? is it easy to replace it?
i tried holding the locking/unlocking for a few seconds to get the lights flashing but it didn't work. anything else i should try?
Romo77
The lights are still not working. Anything else I could try beside pressing/holding the lock/unlock buttons??????????
HELP>>>>>>>>>>>>>>>>>>
