I want more topspeed.
Giallo spyder met
Car: Nissan 200sx -92 Euromodel
How should i do?I made 207km/h in third gear and want to hit 217km/h.Can i take the differential gear from a S14/S15?
Buddyworm
A friend of mine has an S15 diff in his S13. It's quite a bit shorter than the S13 diff (the strawberry silvia did have a 6-speed after all) but the bugger accelerates like a scalded cat.
I'm pretty sure the S14 diff is the same ratio as that S13 one. Can't offer you any suggestions for something with a taller ratio though.
Giallo spyder met
Buddyworm wrote:A friend of mine has an S15 diff in his S13. It's quite a bit shorter than the S13 diff (the strawberry silvia did have a 6-speed after all) but the bugger accelerates like a scalded cat.
Can i use this?http://cgi.ebay.com/ebaymotors...ZWD1V
DALAZ_68
Car: 90' 240sx CA18det
LOL i was t hinking the same thing lol
xsvhp
Car: 1998 240SX KA24DE-T
You can, but IMO, with the time and effort involved, it wouldn't be worth it.
You MIGHT gain 10 mph.
Nunook
what the heck have u done to ur car, so that u can reach 207km/hr in third???
articzap
Car: 2014 F150 FX4
Nunook wrote:what the heck have u done to ur car, so that u can reach 207km/hr in third???
Its called lies.
Two-Fortee
Car: 180sx.
articzap wrote:
Its called lies.
****in right its called lies. Especially considering that every s13 i've ever been in the speedo goes to 180km/h. I think only lambo's could pull over 200km/h + in 3rd...
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
last time i redlined my third gear it only went to 90mph. fourth gear goes to 120mph... and if you pushed it u could reach 130mph which is 207kph (give or take a few).
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
as someone fooling his build intensely.......... if he got those 1236CC(IRRC) injectors rocking properly..... those numbers are possible with proper suspension.
themadscientist
My GTS-4 would do 250KPH near the end of 5th. Not sure what the ratio was but it was definately different the the the GTS-T, it could just crack 200 or so. My RS will do 160KPH in fifth at only 4500RPM but it's an auto rear end with a five speed swap.Change your rear gear if you want to go faster but you will sacrifice acceleration.
boost_boy
articzap wrote:
Its called lies.
If he pushed it stupid-hard in 3rd gear and took it to like 7800-8000rpm, it'll get very close reach that point which is pointless, unless you're trying to get all you can get out of each gear. In my sentra, up to125mph in 3rd gear is not impossible. If you don't have the power, then it's a boring attempt.
Dee
Two-Fortee
Car: 180sx.
207 km would be 130mph...
boost_boy
Two-Fortee wrote:207 km would be 130mph...
Yeah, I do know this you know. Read my post good! If he pushes it hard enough, it's not impossible. Speedometers are always in errors unless properly calibrated and even then, you're still looking at a margin of (+/-) 2-5mph. I just broke some old dyno sheets of mine and looking at two of them (they were all 3rd gear pulls) they appeared to be 125mph and 127mph respectfully @ 8500rpm with horsepower ranging from 299.8whp (127mph) and 312.5whp (125mph). So I don't know how screwed-up dynomometers are, but my car is calibrated and if I can recall my car speedometer is still spot on and this was back in 2002. So again, it's possible whether one wants to believe it or not and I personally gain nothing from lying to any of you for any reason. Just trying to stop this thread from turning into a B.S. flag waving, flaming the O.P. for telling lies. Keep it clean or it gets locked.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Totally do able. You guys all realize that the EDM 200sx's got factory speedos that went to 240km/h, right? This guy has way more power than most of you to boot, and its being used for drag racing.
Using the gear-speed calculator dealy I found on the interwebz, a 3.7 rear end would gain you ~12mph at 8000rpm in 3rd. The calculator also told me that you are only doing 114mph at 8000rpm in 3rd. This is with my huge 245/45/17s on the back. Now I am not one to call BS, if anyone's s13 on here is gonna do 130mph in 3rd its yours, but I know my speedo is pretty unreliable at higher speed. Are you trapping 207km/h at the track or something? What is this engine being revved to?
Also found that "apparently" with those size tires I should be doing 90mph at 4000rpm in 5th. My speedo reads 70. Figure that one out.
dash
Car: s13 ca18
several CA18 S13s gone 130+mph... why is 207km so hard to believe ?
gearing can be tricky. Example;A hot KA24 5spd was stuck in the 11.4s with his 4.08.A single change to 3.54, got him his first 10sec timeslip @ 10.90.He did loose mph tho. I know I'd prefer the quicker ET... screw mph.Same KA24 had gone 10.3 last I ckecked. Still with the 3.54 gear... traps in 3rd
Giallo spyder met
Hi i rev 8800rpm and hit 204km/h and 205km/h and last 207km/h.With 26X10.5-16 M/T and 3.916 rear diff.
I just want about 8mph so i don´t hit revlimit 20-30meters before finishline.
In the dyno i hit 254km/h in 4:th gear.
r34 gtr
There ya go, 8800 would definitely get you there. Yeah, you could probably get those 8mph with a change to that 3.7 ratio ring gear from that s15.
264km/h is freaking fast.
mbmbmb23
Euro S14 Diff's
S14 - SR20DET - MT - R200V - 3.692S14 - SR20DET - AT - R200V - 3.915
Which do you have currently?
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
i wish i had a top speed issue haha
themadscientist
don't you have a "keep it running" issue?
MeanGreenS13
oh no, it runs, just have no money to put more into it to make it fast right now... this ****in us economy BLOWS GOATS
Nunook
ok i take my previous comment back.
8800rpms with a 3.9 and those tires. Thats pretty nice.
