Aaron_9349 »
https://forums.nicoclub.com/aaron-9349-u14669.html
Wed May 12, 2004 12:45 pm
Well, I bought the kit 1/2 yr ago, and I'm just getting it all together now. I'm uprgading the engine, and it should all be done by July or sooner. I'll let you guys know how it goes. This is what I've got going in.
The Turbo Kit w/ Intercooler itself,Crower RodsBlitz BOV
CP or Wiseco Pistons (I bought the CP's and Got the Wiseco's For free) 9:1 comp. I'm trying to pick which one I want
Blueprint and Balance with Crank Micropolished and DeburredToga HP BearingsCometic HP GasketPort and Polished Head w/ 5 Angle valve jobS13 CamsFull apexi GT exhaust (down pipe, and cat back) w/ High flow catFidanza Flywheel Nismo Clutch and Pressure plateNismo MountsDenso PlugsNology WiresASP Crank PulleyNismo AFR w/ 300zx FilterProfec E-01 with optional ign and inj harnesses
Sucks to hear about the running rich problems. Do you have the Profec on that?
If you guys got any suggestions on which pistons I should use, the CP's or the Wiseco's It would be grately appreciated. They are going in the engine in 3 days, so I'm still not sure which ones. The CP's Look better, more oil holes and all forged. The wisecos are coated. Both are same bore 89.5, and comp of 9:1.
Thanks guys
