hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Fri Jun 15, 2007 7:09 am
Are you sure that the A/C leak is not water from the evaporator? Where is it leaking? If it's under the car drips then it is water from the evaporator case most likely.
A/C's generally don't provide very visible leaks unless you see neon green liquid, which would be the oil. In that case your a/c would not be working, or if you turned it on and left it on you might kill the compressor.
Taking the A/C off of a car lowers the value tremendously.
If you do end up taking the A/C off, please remember to go get the refrigerant sucked out by a shop. Do not let someone charge you for it. It's free or if you still have R12 they might even pay you for it, and it will save the environment a lot of heart ache if you don't vent it into the atmosphere.
Moving on to the other problems.. Replacing the water pump is a quick job and it's not very expensive. it's just like 4 bolts, a gasket and some sealer and you're done. Flush the radiator and or look for a tutorial if you are inexperienced with cars.
Replace the water pump and save your engine - if it overheats with no water in it you can easily toast the engine.
Fuel leak could be from the rear end dent - maybe it punctured or shifted the gas tank enough to cause a leak. Those are a pain in the *** and pretty much the only thing to do there is replace the gas tank. You can't weld it back together or it will explode. Two straps hold the tank in, and it's a pain to get in and out, but yeah that's a major to do thing. leaking gas is not good.
So if there aren't any other immediate action items lets move on to the turbo system.One of the most expensive things for this setup will be the exhaust manifold (if you are unable to make one yourself.) Not many people make things for the sohc engine, although they should, so finding a cheap manifold will maybe be hard to do.
In my opinion, if you are buying used parts, why make an exhaust one of the new items? Build your own exhaust, or buy one used or something, save money there beacuse it's not an important item. Spend the most money on the fuel system. Same goes for the IC and piping. Those things are not as important as a good fuel system or a good turbo, so you should buy those items used if you can.
