Wrxrick »
https://forums.nicoclub.com/wrxrick-u54304.html
Tue Jan 16, 2007 1:50 pm
I will be getting a 92'/93' 240sx hatchback bone stock in a month or so. The little knowledge that I have with these cars is the knowledge I obtained from close friends who currently drive 240's . They, however, are only into drifting and told me to make a thread here regarding power. They all use stock turbo's with their swapped SR20DET's. The reason I am getting this car is because it's cheap and its cheap to make fast (cheap compared to many other cars). I want it fast on the highway, and I'm assuming an SR20 is right for me. I would prefer to stay away from the RB/2jz/LS1 swaps. If I use a S13 SR20DET, would it be possible with stock internals to achieve >385whp numbers or would it be easier to go S15 SR20DET? And what Turbo kit would I be looking at? I'm assuming a GT30r kit larger. Probably with a bigger turbine housing as well. I don't mind lag, I won't be drifting and it's simply a weekend project highway car . So my concerns are:
1) What turbo kit should get me easily to >400whp and2) If need be, what internals should I invest in for the SR20 motor? And are SR20DET's rev happy? I may need a stronger internal or two in order for me to keep the turbo in it's sweet spot.3) What kind of an after market tuning solution should I use? Power FC?
Thanks a ton. If you have any recommended vendors for internals and the turbo kit, I would deeply appreciate that as well.
Patrick
