jubee »
https://forums.nicoclub.com/jubee-u26035.html
Thu Jan 18, 2007 7:49 am
actually i will give you guys a break down real quick.
All the Solid lifter kits will require reshimming HKS, BLE (would not recommend these to anyone), tomi, jun. The only kit that does not require reshimming is the MBV solid lifter kit, everyhting comes with it, shims already made all you have to do is measure and put the right shim in.
Solid lifters are not just for high HP cars, you would be surprised at how big of a diffrence they do to the SR, Matt Back Vass dynoed his on his s14 sr20 motor and on 6 psi he made 250 whp and like 200 ft/tq and that was with cams z32 maf and rom tune. 6 psi that not even stock boost.
Also you wont have to get solid type cams, you can still run lash type cams. I am gonna be running BC stage 3 272's cams on my MBV solid lifters. MBV also runs lash type cams on his car HKS step 2's and has no prob what so ever.
yes you are able to rev the SR to 10k+ look at the mazworks site.
If you really think about it all the ohter kits besided MBV are really not kits casue you still have to spend an extra $200 on shims. to me a kit comes complete.
I hope this helps out a bit just figured i would share my knoledge.
