onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Sun Jan 18, 2009 8:38 pm
stitch welding your chassis to "get rid of the flexing noises when [you] go over a bump" is a bit extreme.
you want to compromise your safety - i.e. you are stitch welding crumple zones on a daily driver - because of some noises... yea, that's smart... up to you, but seriously.
I haven't stitch welded my vert, but I have installed a roll bar - not that good of an idea for a pure daily driver, but this has basically become my track car now as it was originally planned when bought. The roll bar alone fixed the flexiness in the chassis when going over railroad tracks; again, this is probably a bit extreme for you case unless you plan on tracking your vehicle regularly.
What suspension/chassis mods have you done already? strut bar? lower ladder bar? nismo power brace? bushings/arms? coilovers/springs & struts?
If you can reproduce the noises, I would suggest first finding out where in the chassis you are hearing the sounds.
There was also a thread either here or zilvia where the poster filled the holes/cavities of his 240 w/ structural foam & it got rid of all the little noises. Seems much less severe than stitch welding, but it's also basically permanent; moisture was brought up as a concern, but the few people who have done it have not had any problems (keeping in mind that these guys have only done it less than a year, iirc).
