shredder »
https://forums.nicoclub.com/shredder-u46229.html
Tue Oct 31, 2006 11:26 am
Mods so far:CA18DET, stockstock injectorsrebuilt, sr t25ssqv bov, recirculatedgreddy 3in downpipersr 3in cat backssautochrome (way too large a fmic for my setup)circuitsports oil pressure, fuel pressure and boost pressure gaugekoyo radiator w flex-a-lite duals
Right now I am having 3 problems with the car.1) It runs rich, very rich2) Boost response is very bad before 4000rpm (then runs like hell - as in fast)3)leaky valve cover (gasket on the way)
I think I found what was causing prob #1. Loose o2 sensor. But I won't be able to verify this until I put the valve cover back on.Problem #2 is being caused by the oversized intercooler and hacked together piping
I am preparing to up my boost to 12psi and here is how I plan on doing it:1st I am installing a walbro fuel pumpthen I am installing a smaller intercooler. (I just picked up one that is 27x5x5.5 3in thick with 2.5 in outlet and inlet) instead of the huge one I have now. I will weld custom piping for this and am contemplating a blow through setup.Next will be a perrin manual boost controllerFinally I will be adding some sort of fuel controller, safc or emanage, a wideband o2 sensor (for tuning), water temp sensor and oil temp
Am I missing anything in this setup? I am trying to get the most out of my car without going larger injectors, full standalone etc... I want a quick spool up and good power band and am hoping to approach 200whp.
