Will do, i check the rockers and HLAs ad nothing was loose, and wiggled barely are at all.PyR0NiAk wrote:This is the point where you need to upload a video with decent sound quality. Without that, all you can get is 1000 posts like Seishuku's.
I forget the size, but Lowes should have metric studs no? Just stud it, and put a nut ontop.conno707 wrote:I need to find a cam cap bolt, i broke one. Ace, lowes, home depot= no luck. anywhere i can get a OEM one online?
How would a ROD just sit there?? That makes absolutely no sense.conno707 wrote:Update, a bad one...
knock has gotten worse, i unplugged the coil pack while it was running, because i read that the rod would just sit there, and not fire. And if the noise went away, it was a main bearing. the noise did not go away on any of them. but i sounds like rod knock IMO. Will make a video tomorrow for sure.
Oh and i found bolt, that was hardened. It was a little to long so i put a extra washer on it. The lengths were the same after that.
