C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Apr 01, 2006 10:36 am
If you go with a T4 on-center turbine, I'd probably stick with a .58 or .69 A/R with a N or O trim wheel. Anything larger and you really better be looking to make some serious horsepower.
Also, to swap to a T4 turbine, you will need to swap the wheel to match as well. You cant just swap the housing onto a T3 turbine. Lastly, if you have an existing kit using a T3 turbine, swapping to a T4 housing will alter the location of the turbo and you'll likely need to modify or get some new piping to match. If you're looking for a bit better flow, you can play with different T3 turbine housings with different A/R's. Make sure the trim of the new housing matches your existing turbine's trim though.
