carlosinseattle »
https://forums.nicoclub.com/carlosinseattle-u40629.html
Fri Apr 27, 2007 8:47 am
I bought a 1994 Q45A as a project car last fall and I'm trying to restore it. When I first bought it, the CU for the active worked fine, and I could retrieve codes with the onboard diagnostics (Switching the N/H switch 10 times, you know the routine). Now I can't do that, and I'm perplexed as to why. The first CU worked fine and I was able to get the codes and repair as neccessary. Obviously the first code was 45, which is low fluid. I added the fluid, then got code 41. After some time, 3 months as the car sat idle, I went to work on it again. Then the active computer failed. So I decided to change out the pump solenoids because I thought that was causing the problem. I changed out the pump solenoids, but the CU still would not work. I bought a CU from a local guy from a car that I knew worked. The CU still threw out a code 41. I knew the solenoids worked because they came from a working car, so I went through the diagnostic procedures to rule out the problems. The solenoid connector and then the connector for the fail safe valve. They then checked out OK, but now my CU won't show anything; no code 55, or 41, or any code. The yellow light just stays lit, but won't show codes. What am I doing wrong? What's causing this to happen? Any help you could offer is appreciated.
