Rogue One wrote:![]()
FSM/QX4/1999
The crank sensor is located at the driver rear of the engine.
Actually bolted to the bell housing on the transmission.
Here is a diagram of it's location.
hayesqx4 wrote:Thank you! But, I am looking for Camshaft Position SensorRogue One wrote:FSM/QX4/1999
Leo1998 wrote:From what i read the cam sensor IS built into the distributor and can NOT be replace, you will have to replace the whole distributor unfortunately these model years for the QX and Pathy are known for having a faulty distributor.
I will have to look tomorrow, Thank you for the links and advice... This is what I bought from autozone, I'm wondering how this is in the distributor... Also there is supposed to be two which is blowing my mind.Leo1998 wrote:I have a '98 Pathfinder so it should be in the same place. Remove distributor cap, remove rotor, remove black dust cover, see camshaft sensors? BTW to remove the rotor you have to loosen the philips head set screw.
As a matter of fact...I think i will go look,
Look at EC 281 page, I think you have a crankshaft position sensor.Leo1998 wrote:I believe it's at the distributor. here's this.
http://www.nicoclub.com/FSM/QX4/1999/EC.pdf
At autozone; the Cankshaft and Camshaft sensors are the same exact thing... This is just turning into a nightmare.Leo1998 wrote:Look at EC 281 page, I think you have a crankshaft position sensor.Leo1998 wrote:I believe it's at the distributor. here's this.
Leo1998 wrote:I did check under my 98 Pathfinder VG33E distributor and it does look just like the EC 281 picture for the 99 QX4 camshaft position sensor.
Here's for my rig
EC 268
http://www.nicoclub.com/FSM/Pathfinder/ ... der/ec.pdf
Ours are the same it appears.
Getting it towed to a shop, I'm no mechanic but I can fix just about anything... Not this time.Leo1998 wrote:Looks like you found your problem and Great Pictures! I will know what to look for now if i have a problem. Let us know when you get if running and what all you had to do. I'm guessing new distributor.
