97JInCO »
https://forums.nicoclub.com/97jinco-u125969.html
Wed Mar 25, 2009 10:17 am
I do have the amps, they are slightly molested though. Just a couple of cut wires. If you are any good with a solder gun, you would be able to re-solder your wiring to the boards. Shoot me an email with your info if you want. I'm sure we can work something out that's in your favor.
Replacing the stereo was a bit time consuming but not at all technically challenging. I ran new speaker wire to the back and was able to determine which two wires to use on either side up front with an ohm meter. I was originally going to run new wire for the front but after sticking my head under the dash, thought better of it. It's pretty much impossible to install anything in the wiring sleeve between the door and the body. I used an adapter from Crutchfield for the power, which made figuring out the antenna sense very easy. Also, I had to use an adapter for the antenna cable, as that Motorola plug is not very standard. All the adapters came with the stereo, free of charge, from Crutchfield.
