Wreckless »
https://forums.nicoclub.com/wreckless-u9702.html
Tue Sep 16, 2003 4:59 pm
Get a Compression test kit at any autozone or Checker or whatever auto parts store you fancy. It should resemble a pressure gauge on a line that is threaded into a spark plug hole.Drive your car around until its FULLY warmed up.Then park it and pull all of your spark plugs, taking care not to let anything fall into the motor, start with one cylinder thread it in tight as hand tight can be to ensure a good seal, and crank the motor with the starter until the gauge isnt rising in pressure anymore, then move onto the next cylinder, etc. until you are done. Anything less than 130 pounds of pressure is something to worry about. Having a buddy help makes this a lot easier too.
