Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Sat Jan 23, 2010 5:58 am
Even if the covers come off, that in itself is not reason to change the T-Belt but 60,000 miles is the right time to do it so that is a good move.I would most definitley replace the tensioner and idler pulleys if they have 180k on them. If the tensioner fails, the belt can jump and destroy the engine. If an idler fails they usually get noisy first, but in the end they seize up causing the belt to destruct and again, the engine is damaged. Valve and piston collision is what happens.
