If it has the automatic trans your fine. It just removes the rev limiters or the speed limiters.. Not sure which try a search..mmm240 wrote:(like kick and throw),but i get a little grind through every gear. what do you think would be the problem? i hear a pivot fork maybe, or a clutch fork?
the car that i bought with a manual that used to be an auto, has a stage 3 (should handle 400whp)(clutch specialties) clutch, and a fidanza flywheel. i recently found out that he did not replace the ecu with a manual one. i have changed the trans fluid to a full synthetic red line fluid,
can anyone help me out. why do i still get a grind?
should i replace the clutch fork and pivot fork? the car still takes the gear, but with a little grind involed. i just can't help but throw it hard, when i am on the gas i am on the shift.
heres your first tip on becomming a racecar drivermmm240 wrote:i know what you are saying and i know i shouldn't, but i can't help it, i want to be a race car driver some day. how would i go about fixing them syncros?
theres a big difference between doing it all the time and doing it at the track.240Knightrider wrote:Everyone needs to be quiet about him driving like a moron..
He drives no different than anyone else that races their car. Nobody barely puts it in gear when they are racing.
my mistake...I was thinking he was talking just when he was driving hard.Kamin wrote:theres a big difference between doing it all the time and doing it at the track.
ooooh, only 10k, how much can i get for a kidney?d!ck wrote:
try a quaife custom-made dogbox once you learn to shift the right way
go to howstuffworks.com, then either go to how transmissions work, or do a search for double clutching.mmm240 wrote:that's depressing clutch and pulling out of gear, depressing clutch again and putting into gear?
i never understood the advantages of that
school me if you don't mind
