I thought I fixed it......
sideways24d
Car: 06 Nissan Sentra SE-R Spec V
So my problem is that I had an Intermittent stall. When the car warms up, it dies. I hooked up the scanner and it said power transistor and coil could've gone bad. Also said check CAS. So I replaced the transistor and hooked up a blaster coil to replace the stock coil. Fired it up and runs amazing. Then it warmed up and I let it idle. Still good. Cruise around the Parking lot and then it dies. No putter, just cuts out. How do I check the CAS? How do I check the distibuter shaft seal?Parts replaced......Cap N RotorBlaster coilPower TransistorFuel Filter (just cause it needed to)I'm really getting sick of not being able to drive. Someone out there has to be of some help i've been stumped on this 4 2 weeks. Please Help Thanks
gotspeed
Car: 96 nissan pathfinder 97 infiniti J30
i cant help but ill bump. hope you get it fixed soon
Bwana
Car: Denali
I'm going to put this one in the KA forum, hopefully you'll get an answer there.
sideways24d
Ne help would be great cause I have to move to Wisconsin in a week. Would be nice to bring my car with me.
sideways24d
cmon guys i really need your help i only have three days til i move back and i really need help with this. anything would help please
CrypticScorpio
Car: 1992 240sx SE Hatch
what happens when she dies? does ur dash blackout then she dies?
sideways24d
No blackouts..... The MIL comes on with all the other idiot lights. You can tell when it dies when the steering goes stiff then you look down and see the lights. You can't hear it or anything just BAM. Dead. Go to the Post Wierdest Problem EVER encountered and it will tell you everything, cause I actually had it running for three days then it randomly did it again.
