Yes, and make sure you replace the right sensor. There's two sensors threaded into the water pipe, the bigger one that's closer to the passenger side is the one you wanna replace.is the CTS the coolant temperature sensor?
i always heard that those injectors cleaners really don't do nothing at all?Shoey2 wrote:mine does the exact oppsite. low power under 3K when COLD. smooth as butter when warm...im going to check TPS and MAF readings and put in some injector cleaner in the next fill up
It might make the situation slightly better, but its usually just a bandaid. You can get reman'd NA injectors(sonic cleaned and flow tested) on ebay for ~$120. I have a set in mine and they work great, plus they come with both new upper and lower o-rings. The sellers name is "TLFperformanceparts". They also sell TT injectors in 370cc, 400cc, 550cc and up.johnshop wrote:i always heard that those injectors cleaners really don't do nothing at all?Shoey2 wrote:mine does the exact oppsite. low power under 3K when COLD. smooth as butter when warm...im going to check TPS and MAF readings and put in some injector cleaner in the next fill up
The only one I have found to make any difference to me is BG44K, its like $20 a bottle/can, but it worked great in my Jeep and a few friends Jeeps. Food for thought.johnshop wrote:i always heard that those injectors cleaners really don't do nothing at all?
Uh. Never seen that one on stores. Where can you get it at?nissanfreak12 wrote:The only one I have found to make any difference to me is BG44K, its like $20 a bottle/can, but it worked great in my Jeep and a few friends Jeeps. Food for thought.johnshop wrote:i always heard that those injectors cleaners really don't do nothing at all?
Wow I had to re-read the last like few posts a few times to figure out what was going on hahaOh god, CTS. I'm sorry. I was talking CAS. I've been up since 10am on Sunday, so I should probably go to bed. There's a way to check the temperature sender (dip it in hot water and watch the gauge) but not sure about the CTS. You can use a multimeter and see if the resistance changes when putting it in hot water, but that's not gonna tell you what the spec should be.
It's a $25 part though, so at least it's a relatively cheap one.
You did clean the connection on it, right? That's like step negative one.
i did clean the connector, it was fairly clean, but it seems to be loose, is not like the other connectors on the rest of the engine that are so damn hard to get off compared to this one. this comes right off no questions asked.Ace2cool wrote:Oh god, CTS. I'm sorry. I was talking CAS. I've been up since 10am on Sunday, so I should probably go to bed. There's a way to check the temperature sender (dip it in hot water and watch the gauge) but not sure about the CTS. You can use a multimeter and see if the resistance changes when putting it in hot water, but that's not gonna tell you what the spec should be.
