kornmanz »
https://forums.nicoclub.com/kornmanz-u77071.html
Thu Jun 23, 2011 9:52 pm
Ok guys, I know this type of thing has been covered in other threads (I've searched) but I just want a quick confirmation from you guys so I dont go spending money on something that wont fix the issue. I was gonna revive an old thread but decided against it.
I think my turbo is bad. I did a compression test, fine. Starts up every time like normal. Occasionally it'll take 2 cranks but starts right up. It never over heats. Dont have oil temp or pressure gauges hooked up yet. Still holds boost well but is noisy.
I am occasionally blowing white smoke out the exhaust. (Apexi Dual N1, Apexi DP, No cat, no condensation inside exhaust)
It is never constantly blowing smoke, and when it does it only lasts a few seconds. It does it very randomly. Always when I'm boosting it. So my mind says turbo. It also makes a weird grinding/rattling type sound when it first enters boost and then leaves boost. I'm thinking shaft play. Basically, foot on throttle, boost starts raising, grinding/rattling noise, boost hits, foot off throttle, boost lowers, grinding/rattling noise.
Then after boost it might blow smoke, it might not. It could do it a few minutes later just for fun.
NEVER smokes when I'm not boosting though.
Can a few of you guys just confirm my theory that its the turbo? I want to be right before I drop a grand on a turbo ya know? Would be pissed if I dropped 1400 to find it was something else lol. Oh yeah its a highly modified red top SR, stock T25.
If it is the turbo, are ISIS turbos any good or should I stick with garrett?
