Dude...this is a tech forum. Use grammar...even a little is better then none. Like maybe some caps and a period or 4. Take the time to communicate what the problem is and we'll take the time to help you out.B-rad Smizzel wrote:i just got over spark issues and now i think that my injectors are leaking i have a 1995 s-14 with top feed injectors aftermarket fuel pressure reg and a custom fuel rail yesterday my car was spuddering and cutting out and running rich so i let it sit all night put new plugs in it and it barely started but it did and ran and pulled just fine no spudder or cut took it home and let it sit for about a half an hour and it wouldnt start so i let it sit for ten hours then i primed my fuel pressure up and looked at my gauge it went from 40 to 20 psi in about 60sec pulled my plugs smelled like gas and plugs were wet
This is priceless.B-rad Smizzel wrote:ya sorry about wrighting like a crack head
thanks thats all i needed was how to diagnose it i will try it tomarrow and let you know480sx wrote:^^ Dude this is B-rad Smizzel.
Alright, first of all. If your car is running like you say, it is most likely running pig rich. In addition, you have fresh rings that arnt seated yet. This is THE most frightening and one of the most dangerous situations for a new motor. Basically, because your rings havnt sealed fully with the cylinder walls the engine will see a very high level of blowby.
Basically, gas gets into your oil QUICK, and ruins your motor if your running rich on new rings. Pull your dip stick. Smell it. If it smells like fuel AT ALL, change it.
Get the car running. Pull injector plugs one by one with the motor idling, replacing them after you pull each one and leave it unplugged. Your looking for the following by doing this test. An injector plug that, when unplugged does nothing or little to change the idle of the motor. That indicates you have a leaking injector or rail.
Otherwise, unplug the maf and see if the car runs ok. Could always be maf lol, i didnt really read what you wrote.
Modified by 480sx at 3:01 PM 8/2/2009
ya this car has been nothing but trouble since i got it bc two winters ago i blew my motor and i had ams (chris) tune my s-mfac and it ran like a dream till nowChris28 wrote:You dropped the cash for an AMS crate engine but only got an SAFC for tuning? Get a real tune for your MAF and injector size then start troubleshooting. I'm betting your problem is in your lack of tune.
