I think my engien is hating me
240 Trainee
Ok, I got tyhe CA running off the temp sensor, it sounded great!! Then, got my piping, tried connecting the MAF, and it was hard to start, and revved to 3,000 rpm, which sounds like the MAF. but, the wiring is correcte, I have checked it acouple different times. Then, Dee was trying to tell me how to read my ECU. I didn't get it, I was tired, and wanted to go to bed. But now, the engine doesn't fire at all. I have fuel, but the engine isn't sparking. and, when I disconnect the crankangle snesor, the EGI fuse buzzes. So, The ECU must be in somekind of safe mode, andyone have any answers on this? I get my exhaust this week hopefully, and I want the car ready!!
240 Trainee
No one?
240 Trainee
come on guys, I know someone has to have some input.
boost_boy
I would hope for the sake of your ecu that your car is grounded properly. I can't stress this enough! I still would like for you to try and get your ecu lights to start cycling. Check all fuses and relays by moving the relays around by matching their colors. Make sure that the crank angle sensor still has control of the fuel injectors. Smell your ecu and see if you don't smell something cooked. Very important to ground that engine! Remove the ecu fuse in the engine bay fues panel and rotate the car's engine. The reinstall the fuse and call me and let me know if the lights function after using the process I explained to you...
Dee
240 Trainee
Ok, I'll do that. I need to do some more ground points. I was going to call you tonight, Dee, but you've given me a good list! I'll work on it. The ECU doesn't smell burned or anything, but I'll work on the grounding. And that EGI fuse buzzes again when I unplug the Crank angle sensor.
nab911
Car: 93 Nissan 240SX SE
Well mine turned over when i turned the key but none of my lights work and right now my ecu is hanging by the wires i soldered and taped and when it started swinging i heard some relay/switch clicking like crazy in the engine bay... so yeah... Im not sure whats wrong but i know i grounded the block and the intake mani and the fust block near the battery. WHats wrong dee??!!!
biosehnsucht
nab911: hanging by the wires is a bad idea, you could be causing momentary shorts..
240 Trainee
Ok, well, I grounded the heck out of it!! 4 gauge ground strap, and evey ground cable on the harness is grounded. But, when I took off the exhaust manifold and turbo to install the SR turbo elbow, I found that the oil line into the turbo was cracked. So, gotta convince one of the guys at the HVAC shop to help me out; I don't want to buy a pipe flaring kit!!
boost_boy
Quote »Well mine turned over when i turned the key but none of my lights work and right now my ecu is hanging by the wires i soldered and taped and when it started swinging i heard some relay/switch clicking like crazy in the engine bay... so yeah... Im not sure whats wrong but i know i grounded the block and the intake mani and the fust block near the battery. WHats wrong dee??!!![/quote] Do the same thing i told 240trainee to do by removing some of the relays to see what happens or switch them around as well as removing the ECU 10amp fuse in the engine bay's fuse panel. Apparently you guys got something hooked-up a little wrong or don't have enough stuff hooked-up. The little orange wire on the dash/instrument connector harness is very important. If you have any of those wires hooked-up wrong, it will give you dramas. Most importantly, that little orange wire with the grey dots is of the most importance as it is the wire that keeps the computer powered-on while cranking. Check it and make sure that when turn the key to start, it receives a 12volt signal. If not, you've blown a fuse or relay and it will because something is hooked-up incorrectly.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i will never forget the first time we went to crank my car over. everything was wired up, i was a little skeptical about our wiring skillz though, but my dad kept telling me it would be fine. i got in the car, put the key in the ignition and my dad said: "so how much can we get a new ecu for?". i was like, "oh, gee, thanks dad for your final vote of confidence". contrary to popular belief though, i turned the key and it went "rrr rrr rrr vroooooom!!". yes, my car started on the 4th turn after sitting for about 6 years.
just wanted to share, i am a little bored right now.
- tim
240 Trainee
yea, that was my plan! Lol, didn't quite turn out that way. but you know, there is nothign wrong with a challange.......
240 Trainee
Ok, well, worked on it tonight. I think the ground is my problem; even with my 4 gauge strap, the tach started goign hatywire again. So, I connected the wires to make the Car front batteried(lol) again, but I need to charge my jumper box overnight. Gonna give it another go in the morning. BTW, a brake line from advance auto works great as an oil feed line.
240 Trainee
Ok, well, my Crank angle sensor doesn't fire the pistons or anything anymore when i removed it, and tried turning it. maybe I fried it? I dunno. looks like I will probably be searching for a new CAS.
boost_boy
I seriously don't think it's the CAS as they rarely go bad to the point whereas they can't fire the engine at least at 180* rotation. ECU is the culprit. Suspect it. You won't be the 1st and won't be the last.
Dee
240 Trainee
Ok. Sorry about the phone Dee, it cut off again. I'll call you tommorrow. I really wish I could spring for the SDS system now....... LOL.
