I think my car is running a little hot...
brisknfade
Car: NB8C FTW
Or my temp gauge is seriously messed up...
One minute it's burning up, and the next it's normal. Me and my freind were just laughing watching it go up and down. And this was at Idle, at night, with the hood open. Didn't even feel that hot either.
I don't get it. Any thought?
i2ice4m3
Car: COUNTERSTRIKE!
theres a black plug next to the coolant temp sensor. that sends temp signals to ur instrument panel and it may just be loose. mine did that, except it never went above my engine temp. hope it gets u a step closer to solving that problem!
mine is ka24e btw, but ur motor components should be similar
sdtouge
Car: 1990 240sx coupe
some gaugess just stop working i guess. mine did the same thing, so i got a new one.
PalmerWMD
Car: 2004 350Z
Or sticky T stat.
Or clogged rad ( is yours original?)http://nicoclub.com/zerothread?id=88604
Fred..
Toddles82
Car: Computers, Water Skiing, Cars
check your grounds! I had a bad ground and it caused my gauges to wig out. I could hit the brake pedal and make the gauges bounce. I know the symptoms aren't the same, but I would still check your grounds.
si1via
Car: '93 240sx
dude that would worry me a bit. I have been getting a little above the middle point on my temp gauge lately. I didn't notice anything out of ordinary until my friend pointed out I was losing coolant. Then I check my resovoir and it was below minimum line. Still haven't figured out where the leak is coming from. It'll only leak if I turn off my car for a long period of time. It only leaks some days too, weird. My dad thinks its an internal leak from the waterpump. Lucky I don't havee to comute too far.
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
you may want to check and make sure you have coolant. Also make sure your thermo stat is workin
PapaSmurf2k3
Site Admin
try turning your heat on when that happens, that used to happen to me, and it would blast cold air with the gauge up then all of a sudden really REALLY hot air, and the gauge would go down FAST, leading me to beleive there was air in the system so i bled it out and its been kosher ever since.
