Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Sat Sep 19, 2009 3:45 pm
Buy a smashed parts car and swap everything over. You will need the pedals, transmission, flywheel, clutch, pressure plate, master and slave cylinders, driveshaft, plus all the hard and soft lines to make things feel happy. Plus the diff flange if you get the stuff from an 87+. I suggest a parts car because everything will be there and if you piece it together you might be halfway though and realize you forgot to get something. I say smashed parts car because it will be cheap and the damage won't likely affect any of the clutch/transmission components, while you might be able to part it after the conversion and recoup your money.
