I dunno what to tell you man. If you're POSITIVE that its getting power and its still not turning on, then you have a bad unit.JackIrish wrote:I have no idea what happened but i got done wiring in my Sirius radio today and went to turn on my radio...and it's completely dead. it's got power to the unit and it's grounded as well we tested it numerous times with the volt meter but it just seems like the head unit gave up the ghost...any idea on what this could be? or what could cause this? all fuses are good and there's power everywhere. in all the work i've been doing lately i haven't touched any radio wires and it worked about a week ago..
My mistake..my actual headunit is dead..the Sirius is fine..it just has nothing to broadcast to due to the fact my radio has died. we tested the connections at the wiring harness and it had ground and power =(xekushnr wrote:
How did you wire it up? Did you hardwire the unit in or is it just plugged into the lighter? If you hardwired it how did you do it?
Wait...is the Sirius unit dead, or is the actual head unit dead? Now I'm confused.
Yea i'm going to try and just get it 12v to see if it comes to life! a few more tries tomorrow before i buy a new unitSilent_Fart wrote:try pulling 12v from somewhere else in the car maybe? I have ghetto rigged stuff in my cars to make sure it works or to get it to work for a short amount of time.
Did you test it with the key on? Did you test both power wires? Check the fuse on the back of the radio, and also check the radio fuse in the fusebox. If all that works out, test it directly to the battery.JackIrish wrote:My mistake..my actual headunit is dead..the Sirius is fine..it just has nothing to broadcast to due to the fact my radio has died. we tested the connections at the wiring harness and it had ground and power =(
