too bad it wont turn like an mr2 anymore
virus77 wrote:heres some facts I picked up on each one of those motors, this guy is nuts.
The General Electric T58 is a free-shaft axial flow gas turbine. The compressor has 10 stages with variable inlet guide vanes and variable stators on the first three stages. The compression ratio is 8.4:1, it flows approximately 13.7 lb/s (11,000 cfm) @ 27,300 rpm. Specific fuel consumption is 0.64 lb/shp/h. The engine weighs 350 lb [159 kg] and produces approximately 1,400 hp each. With a 3.25:1 reduction gearbox this engine will produce 1,270 lb-ft of torque at 6,000 rpm.
since when are jets measured in hp and torque?
theres no mechanical side to it whatsoever...whoever you got that info from needs help
theres approximate numbers to figure out how much horsepower a gas engine would need to make to be as powerful as a jet, but jets arent measured in gas engine specs
