Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Mon Sep 12, 2005 5:11 pm
The front will be compressible with just a C-clamp, but open the bleeder, and tighten it before you let the clamp off, do the same on the rear. This will prevent damage to the master cylinder and proportioning valve. Also, if you are already there, you should replace the fluid. The service interval is 36mo/36K mi, and no one ever follows it. But if you are getting stainless lines, wait until then. I just did all at once.
