EstoMax »
https://forums.nicoclub.com/estomax-u17537.html
Sun Jul 27, 2008 3:46 pm
hey guys,
I just pulled my subframe last night, and took it apart today, but i ran into a problem, I can't seem to get the bolt out of the bottom of the wheel hub bracket, see pic 1. I remember reading that i need some special puller tool for it but I don't quite understand why... Anyone have a trick to get the control arm out of that thing?
see below:
Also, I didn't think and I didn't take the 36mm bolt out of the center of the hub, so now i'm stuck with the axle attached to the hub bracket assembly. What would you recommend as far as getting the axle off? Should i clamp the hub in a vice and do it that way after i get the control arm out?
cheers for any help!Marko
