HachiRoku »
https://forums.nicoclub.com/hachiroku-u1165.html
Sun Nov 24, 2002 12:55 pm
after another diagnostic drive, here's what i find....
my car gets the whirring/whining sound when it is driving or when i'm revving
i hear it through all the gears except 5th. 1st-2nd gear is pretty loud, past 3000 rpm the pitch gets higher. 3rd gear is not as loud, but can still be heard pretty well. 4th gear it gets more silent. 5th gear you really don't hear it, but there is a rocking/rumbling noise.
revving the engine will whine/whirr it regardless of whether or not the clutch pedal pressed in.
when i let off the gas and coast in gear, it will whine/whirr all the way down to about 1000-1500rpm before it goes away. coasting while in gear on a cold engine seems to be louder than when it is hot. i think it sounds like a bus engine when they coast and let off the gas. if i put it in neutral and coast, it will go away as soon as the rpms could drop.
i can't say whether or not it whines/whirrs when the clutch pedal is pressed in, but when the engine was cold, there was a very very silent whine, you really can't hear it unless you actually tried to listen for it.
now is that the symptoms of a bad pilot bearing? i am trying to troubleshoot this by myself because most of my friends don't know cars enough to know what to listen for...i have a friend close to home who knows about as much as i do....he thinks it's the pilot bearing too, but we never actually tried to figure out if it was the pilot bearing.
please reply asap, i only have til wednesday to make the decision, after that i'll have to put off the repairs til i have time again
