Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Sat Apr 09, 2005 6:00 pm
I think since my car is like almost 10 years old, I just need one that is in better condition. This was and East Coast (New Jersey) car so I can only imagine that the alternator got a hefty workout.
No! I do not really play loud at all when driving. In fact i am very conscious about hearing protection, I need to use my ears, hearing as a pilot to pay attention to Air Traffic Control and respond. I like clean pure music, Not loud. I don't even play it loud when I sit in the vehicle. I usually only play at higher volumes, as a demonstration for my customers. Then sometimes i'll do it with the car turned off, only starting it if the demo last longer than one or two songs. I have just one 10" sub in a sealed enclosure, not vented, or bandpass.
The 150 amp ANL fuse at the Battery obviously limits the amount of total current consumption. I would bet the max current pulled by the system is near 100amps and only for short times.
I know that this year it has been particularly bad, and the Red top is only 2.5 years old. The vehicle always starts, just I notice dimmer lights on the way home at night. I think part of if has been the weather, it has been rather odd this, very foggy, and cold, uncharitaristic of Portland. Last summer the AC was used every Day, when the temperature was in the 90, and up.
I think this alternator is just tired it still puts out almost 14 volts at 3000 rpm. I don't have a volt meter installed in the Car, but plan to add one. I just used my fluke and the LED light up one on my old capactior. My newer Monster Cable cap is just plain no display. The power cable at each amp is 4 gauge, 2 gauge from the Battery back to the trunk, 4 gauge grounds for the amps and 2 for the cap. I also add/upgraded the ground at the battery, and alternator. I checked the current consumption of all accesories at rest, and no significant draws anywhere, the battery never goes dead just gets weaker and weaker towards the end of each month. Then I charge it for like 30 minutes in the shop at work and the voltage stays good for like two weeks and starts dropping
I have an SE, and the 90 amp model alternator. I'll have to look in to the GM style used in those Z's. They make 240amp alternators for the larger GM trucks. I really can't afford to pay that much for a re-wound, that is more than what it would cost for a Stinger, at dealer cost. I don't want to add an extra alternator, too much work, and equipment to make it work right.
I think that is about it. keep the ideas flowing.
