i think i might be crazy
4gotn1
Car: 1990 Nissan 240sx (coupe)
i did search. not a single thing close to what im thinking.
ok heres the deal i hate how my 3rd gear pulled. quite frankly it sucked balls. my car would rip in 1st and 2nd, hit 3rd and its like it falls on its face, 4th and youve got power again.
so i did a little research and found this out.
240sx 300zx FS5W71C FS5R90A1st 3.321 3.350 2nd 1.902 2.056 3rd 1.308 1.376 4th 1.000 1.000 5th 0.759 0.752 Rev 3.636 3.153
a 300zx transmission has a little bit better of a 3rd gear. as well as a much nicer 1st and 2nd. and if i got a .838 from a frontier then i should have a pretty nice gear setup. i played with the gear combos in a nice little calculator i got and got these results:
Gearbox:- 1st - 3rd from the 300zx stock 4th .838 5th w/ 4.08 finalTyre:- Michelin all patterns 205/60 x 15-------------------------------------------------------------------------------------------Top Gear gives 20.938 MPH/1000 RPM and a top speed of 136.096 MPH at 6500 RPM
Engine speeds in top gear:- 30 MPH = 1433 RPM 40 MPH = 1910 RPM 50 MPH = 2388 RPM 60 MPH = 2866 RPM 70 MPH = 3343 RPM 80 MPH = 3821 RPM 90 MPH = 4298 RPM 100 MPH = 4776 RPM
Top Speed in 1 gear = 34.044 MPH And changes into 2 gear at 3989 RPM dropping 2511 RPMTop Speed in 2 gear = 55.471 MPH And changes into 3 gear at 4350 RPM dropping 2150 RPMTop Speed in 3 gear = 82.884 MPH And changes into 4 gear at 4724 RPM dropping 1776 RPMTop Speed in 4 gear = 114.048 MPH And changes into 5 gear at 5447 RPM dropping 1053 RPMTop Speed in 5 gear = 136.096 MPH
Gearbox:- 1sr - 3rd from the 300zx stock 4th and .838 5th w/ 4.64 final Tyre:- Michelin all patterns 205/60 x 15-------------------------------------------------------------------------------------------Top Gear gives 18.411 MPH/1000 RPM and a top speed of 119.670 MPH at 6500 RPM
Engine speeds in top gear:- 30 MPH = 1629 RPM 40 MPH = 2173 RPM 50 MPH = 2716 RPM 60 MPH = 3259 RPM 70 MPH = 3802 RPM 80 MPH = 4345 RPM 90 MPH = 4888 RPM 100 MPH = 5432 RPM
Top Speed in 1 gear = 29.935 MPH And changes into 2 gear at 3989 RPM dropping 2511 RPMTop Speed in 2 gear = 48.776 MPH And changes into 3 gear at 4350 RPM dropping 2150 RPMTop Speed in 3 gear = 72.881 MPH And changes into 4 gear at 4724 RPM dropping 1776 RPMTop Speed in 4 gear = 100.284 MPH And changes into 5 gear at 5447 RPM dropping 1053 RPMTop Speed in 5 gear = 119.670 MPH
so the car would scream to its top speed if im gettin this right. might be nice for a drag car. but i dont know if the gears will swap. does anyone have a 300zx transmission they might be willing to donate to the cause for a cheap price? i know that it would suck for gasmilage but i just dont care about it. i would prolly go with a slightly larger tire than listed. maybe some 225/50's so what does everyone think? am i crazy?.
240crawler
Car: 1991 240sx
4gotn1 wrote: am i crazy?
Yes!
No, really, just spend the extra money on the 4.64. Save money for easy but worthwhile mods. If you are a serious drag racer, then I say good idea. But if you are a streeter, than leave your transmission alone, change rear gears, and put on bolt-ons or NOS.
4gotn1
i have almost every bolt on allready. not much more that i can do to it. cam, itbs, flywheel, driveshaft, 4.64, high compression. thats all i can think of left to do to my ka24e, besides turboing it. which i would love to see what it wll do with some gears, before i do any of the other mods, except for maybe flywheel, cam and driveshaft.
pregmantis
all those things you have left to do will make your car run, really run good but your reliability will really run away. DO IT! 4.60s will kill your top speed unless you change the transmission gearing, if its cheap for you to do both(transmission/diff) do it.
90SXSE KA24ET DREAMS
Car: 1990 Nissan 240SX SE 5spd KA24E-T project
werid... i have no problems with power in 3d gear.
1st gear for me sucks.2d gear power3d gear power
