goody94q45 wrote:Sounds like you're on step 1- Remove the armrest. Get a large flathead screwdriver and pad the tip with a clean rag. Place it between the armrest and the padded door handle, push it down about 1/2" and gently pry to the rear. The armrest will pop back and lift off. Removing the armrest exposes the 3 screws that must be removed. Good luck.
I wouldn't even use a screw driver since it is very easy to leave a mark behind. What I do is grab the armrest with both hands and pull back as I push down. It helps to make grunting noises when doing this. Look inside the FSM to see how the arm rest tabs are positioned so that you have a good idea on how to take it off.
