I Think I'm in Trouble
BetweenPandR
Hello to everyone, and let me thank you for this invaluable resource.
I have a '95 Q with around 130k. Recently (the past two weeks) I noticed a slight whine, and yesterday I smelled something like burnt clutch. I don't drive it much, so I didn't attend to the whine sooner.
There is no slipping, hestiation, or clunkiness in the transmission. Everything is smooth and solid.
Any help would be much appreciated.
Thank you
Q45tech
Take it to your local expert for a complete once over, just as you do or should do every 90 days.
captainluigi
Car: 1996 q45t
LOCAL EXPERT! uh, Dennis I believe that would be you.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No maintenance history?
How can we guess with that paltry description?
When did you last replace you accessory drive belts and pulleys?
qship96
Car: 1996 Infiniti Q45
Pull transmission dipstick.... how is fluid level, color, smell, taste? What is your ATF replacement interval, since brand new?
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
Burnt clutch could be a brake hangin' up
Woot!
Car: 1991 Infiniti
Power steering? Did you check all fluid levels?
Q451990
Could also be an idler pulley seizing and causing the belt to slip... so many possibilities.
Heath
goody90q45
Car: 1992 Infiniti Q45 (sold)
BetweenPandR wrote:I have a '95 Q with around 130k. Recently (the past two weeks) I noticed a slight whine, and yesterday I smelled something like burnt clutch. I don't drive it much, so I didn't attend to the whine sooner.
maxnix wrote:When did you last replace you accessory drive belts and pulleys?
Q451990 wrote:Could also be an idler pulley seizing and causing the belt to slip... so many possibilities.
Check your idler pulleys.
BetweenPandR
Thanks everyone. I took it in yesterday; I should know by Tuesday.
