Who told you Jim Wolf has trouble with 50 lb/hr fuel injectors? I've been running that for 2 years no problem...UncleBen wrote:I am scratching the Emanage, its for sale with the Eo1 if anyone is interested. I decided to get a JimWolf ECU. Doing some research, I know JimWolf's tunes are more conservative, which is fine. I read that the JimWolf computers have trouble with 50lb injectors which I thought about running, but figured I'd stick with my SR fuelrail and 370's because of that issue. I have an SAFC2 that I was going to sell, but will keep it and run off the JimWolf ECU just to fine tune the A/F's, etc. Um what else; I'm going to pick up a z32 MAF; the KA's dont like over 200hp do they? I want 240whp or so, so a Z MAF wont hurt regardless. How's this sound?
No, Enthalpy is better because he makes more power and still has reliable tunes. If I were to go ECU reprogram, I'd go Enthalpy.UncleBen wrote:And, is the only reason Enthalpy is better is because of its turn-around time?
I just e-mailed Enthalpy's assistant, Scott, a few weeks ago and if you need a retune because of changes to your setup, it's $125. And he just send you a new chip, so there is not really any downtime.UncleBen wrote:Plus, later on if I change some setup I dont want to pay another $500 to get my ECU flashed again (enthalpy, right?).
http://www.deatschwerks.com/UncleBen wrote:Where is a good place to buy the deastchwerks injectors anyway, I want to know more about this getting credit for my 370's etc.
Not only that but JWT timing map is a lot more conservative compared to Enthalpy's map. That's why the lines jump up and down so much.IWannaS15 wrote:Glacier, thanks for the link to that dyno. You can see the Enthalpy stays right below 12:1 on boost, while the JWT drops below 11.5 at some points.
Exactly the point I was trying to get across. I should have plenty of fuel with 550 injectors to handle any boost spike my little GTiR turbo can throw out. I'll probably run no more than 7-10 psi daily, but the comfort of knowing that I am good to go if I should hit 15 psi, (whether accidentally or intentionally), is worth the little bit of extra $$ for the larger injectors.Florida240sx wrote: If you happen to ge a boost spike then you got the extra fuel dumping unlike the 370cc whihc would go lean very quick and blow your motor.
